Quartus and make get stuck adding the Agilex HPS IP
Could you share you full system info that was tested recently that was having the issue?
Can you share me the design that you are seeing the issue so that it could be replicate from my side? I just need to check.
I just tried using make_generate_from_tcl it was fine, I used the GHRD 22.1 and 22.1 Quartus.
- LIacob4 years ago
There is no design yet. I was trying to build one from scratch, and could not add the hps ip.
Now I have just installed Quartus Pro 22.1 on Windows and it seems to be working just fine.
I don't know what the problem is/was, but it did not work on either of the two linux distributions I have tried.
I have to mention I am using the same license on all 3 systems, yet windows works, but linux does not.
Thanks a lot for checking its not a GHRD problem. If I somehow find the cause of this problem on linux I will come back here with an answer.
