Quartus and make get stuck adding the Agilex HPS IP
Oh btw you're using your own design, could you share it?
I want to replicate from my side.
- LIacob4 years ago
It is not about the design.
I open a brand new empty project, select the desired agilex board and try to add the HPS ip from the platform designer, and it gets stuck.
Similar, I followed the flow from the rocketboards web page (https://www.rocketboards.org/foswiki/Documentation/BuildingBootloader#Agilex_45_Boot_from_SD_Card -> B. Build Hardware Design Chapter) in a try to build your agilex project. The result is the same. The terminal hangs within the "make generate_from tcl" with the following message forever: "2022.10.03.13:50:29 Info: add_component agilex_hps ip/qsys_top/agilex_hps.ip intel_agilex_hps".
Could you please check that the flow from Rocketboards is working?
