Jeremy_S
3 years agoQuartus 20.4 Cannot Configure FPGA to .jic files
Greetings, We have a PC that used to be able to load .jics on our FPGAs (Stratix 10), but now it keeps failing some time during load with the error "jtag chain broken". I have tried a different USB ...
Jeremy_S
3 years agoHi Fakhrul,
Thank you for the response. Both PCs are using Windows 10, Quartus 20.4, using the same .jic files on the same FPGAs, same USB blasters and related cables.
Is there something specific I should be looking for with the PC that could be causing this issue?
Thank you
FvM
3 years agoHi,
some download cables (e.g. Arrow Blaster, I think also USB Blaster Ii) are storing JTAG frequency settings on the computer. Also some global Quartus programmer options may affect operation.
- Jeremy_S3 years ago
Yes, both have the frequency set to 16 MHz and the global options are the same. (Assuming that's the menu where you hit tools/options in the programmer)
Thank you.
