PPerd2
6 years agoQuartus 18.1 transceiver twaddle
Hi.
I'm having fun with the transceiver once again. I am trying to set up a simple config in Arria VGZ:
10GBASE-KR (10G, AN, LT, 644 MHz ref, ATX PLL), TSE (ATX PLL), 10GBASE-R (CMU PLL).
I fit...
- 6 years ago
Hi, Thanks for your update and test results. If I understand it correctly, the PMA AUX is the calibration block. For your information, you would need to connect reconfiguration controller to all the transceiver instances so that the offset cancellation can be performed to ensure correct funtionality of the transceivers. You can share the reconfiguration controller for them to save logic and test if can pass Fitter compilation. Please let me know if there is any concern. Thank you.
CheepinC_altera
6 years agoHi,
Just would like to follow up with you if there is any concern. Thank you.
