12 years agoQuartus 14.0 Clock generation
Hello All, So i have a prototype where we use a 27MHz clock. A problem we are having is that Qsys can't make all the clocks. We can boot as far as UBOOT from NOR flash with CSEL on "10" with ...
12 years agoSo found the problem.
I had the EMAC configured to get out of reset on power good. The HPS uses the same power good. We did this because on a older prototype this solution works. But i geuss it's was no good practice. The EMAC needs a periode after power up in which you must not talk to the EMAC. So we changed the setup, so now the EMAC powers-up before the HPS. And it works fine. Thnx for all the hints and tip. Much appreciated.
