12 years agoQuartus 14.0 Clock generation
Hello All, So i have a prototype where we use a 27MHz clock. A problem we are having is that Qsys can't make all the clocks. We can boot as far as UBOOT from NOR flash with CSEL on "10" with ...
12 years agoJust for reference.
I also use custam clock ( not 25MHz) and emac. my boards are works good. In my case, we should set emac clock 250MHz exactly. Qsys can not generate exact 250MHz in case that osc not 25MHz. Try to change emac clock 250MHz(exactly 250MHz) by "edditing pll_config.h"
