NShin3
7 years agoQsys/Platform Designer does not generate submodule files when using two Avalon MM Slaves
I have created custom Avalon MM slaves. I want to connect them to a Master. The Qsys/Platform Designer tool does not generate submodule files when more than one Avalon slaves are connected to Avalon...
NShin3
7 years agoHello Anand,
I followed this process but still have the same problem.
Image 1 : Single Avalon MM slave.
-- Submodules folder generated with all sub files.
-- inst file is also generated.
Image 2 : Two Avalon MM slaves.
-- No Submodules folder generated.
-- No inst file.
-- Only QIP file.
Thanks and Regards,
Niranjan
NShin3
7 years agoHi,
I followed this same document to create custom components.
Only difference is I am using conduit signals to get data from FPGA modules instead of instantiating inside slave MM interface.
I have shared verilog files of master and slaves in the comments below.
Thanks and regards,
Niranjan
