NShin3
7 years agoQsys/Platform Designer does not generate submodule files when using two Avalon MM Slaves
I have created custom Avalon MM slaves. I want to connect them to a Master. The Qsys/Platform Designer tool does not generate submodule files when more than one Avalon slaves are connected to Avalon...
NShin3
7 years agoHello Anand,
I followed this process but still have the same problem.
Image 1 : Single Avalon MM slave.
-- Submodules folder generated with all sub files.
-- inst file is also generated.
Image 2 : Two Avalon MM slaves.
-- No Submodules folder generated.
-- No inst file.
-- Only QIP file.
Thanks and Regards,
Niranjan
AnandRaj_S_Intel
7 years agoHi,
May be due to custom component.
follow the steps from below file.
Can you share the project?
Anand
