15 years agoQsys module with JTAG Avalon Master and Slave
I have created a Qsys system that consists of a JTAG to Avalon Master Bridge (Master) and an Avalon Memory Mapped Slave. The slave is created using a .vhd file which has the following ports:
csi_clockreset_clk : in std_logic; csi_clockreset_reset_n : in std_logic; avs_qsys_read : in std_logic; avs_qsys_readdata : out std_logic_vector(15 downto 0); avs_qsys_write : in std_logic; avs_qsys_writedata : in std_logic_vector(15 downto 0); avs_qsys_address : in std_logic_vector(15 downto 0); coe_writedata_ext : out std_logic_vector(15 downto 0); coe_write_ext : out std_logic; coe_read_ext : out std_logic; coe_address_ext : out std_logic_vector(15 downto 0); coe_reset_ext : out std_logic; coe_clk_ext : out std_logic; coe_readdata_ext : in std_logic_vector(15 downto 0) And, I perform the following assignments: coe_writedata_ext <= avs_qsys_writedata; coe_write_ext <= avs_qsys_write; coe_read_ext <= avs_qsys_read; coe_address_ext <= avs_qsys_address; coe_reset_ext <= csi_clockreset_reset_n; coe_clk_ext <= csi_clockreset_clk; avs_qsys_readdata <= coe_readdata_ext; The address map for the Qsys is 0x00000000 to 0x0001FFFF. Now, I used this Qsys system and an external RAM (megawizard function) to perform reads and writes to the memory. I am using System Console, in Qsys, to run a TCL script to perform reads and writes using the following commands: master_write_16 and master_read_16 I have also added a signaltap file to the project to monitor changes in the signal values. Now, in the System Console window in order to read and write to address 0x0000, I used the following commands: 1. master_write_16 $jtag_master 0x0000 0x1 2. master_read_16 $jtag_master 0x0000 1 After each command I check the values shown by signaltap. For all the address entries, the data written and read for the memory is consistent. But, the address shown by signal tap (coe_address_ext) is not the same as the address I accessed using the TCL command. For example, when I type the following commands in the System Console window, the following signaltap values for the address appear- tcl command ----------------------------coe_address_ext (shown by signaltap) master_write_16 $jtag_master 0x0000 0x1 -------------------0x0000 master_write_16 $jtag_master 0x0002 0x3 -------------------0x0000 master_write_16 $jtag_master 0x0004 0x5 -------------------0x0002 master_write_16 $jtag_master 0x0006 0x7 -------------------0x0002 master_read_16 $jtag_master 0x0000 1 ---------------------- 0x0002 master_read_16 $jtag_master 0x0002 1 ---------------------- 0x0002 master_read_16 $jtag_master 0x0004 1 ----------------------0x0004 master_read_16 $jtag_master 0x0006 1 ----------------------0x0004 I do not understand as to why is the address value captured by signaltap different then what I am entering using tcl command. Is there some kind of address mapping? I will appreciate if someone can help me with the issue. Thanks.No RepliesBe the first to reply
