14 years agoQSYS, minor glitches with parameterized ports
Encountered some minor glitches in QSYS in regards to vhdl generics in Quartus 11.0sp1. Found workarounds to all of these, but they had me puzzled for a while. I designed several bus modules wi...
14 years agoIf possible I recommend opening a service request and attaching your component so that the tools will be fixed: http://www.altera.com/mysupport -1 is used as a default for a parameter which will get filled in later.
By the sounds of it the default value is not being filled in correctly. I'm guessing if you add an elaboration callback to the .tcl file you can work around this bug. If you want to see an example take a look at the .tcl files for the read and write masters in this design: http://www.alterawiki.com/wiki/modular_sgdma (verilog based but the .tcl commands will be the same)
