MK_ABQ
Contributor
3 years agoQsys Base address
Hello, I see that individual block in qsys assigns its own base and end address. Let's say if I add new blocks in qsys, and assign new base address using the following gui option, will the base ad...
- 3 years ago
(Platform Designer, not Qsys FYI)
The Assign Base Addresses option will set the base address for any unlocked agent interface. You can click the little lock icon to prevent this command from potentially changing the address if you have manually set the base address yourself. The end address is automatically set based on the design of the component and the base address set. You can't edit the end address.
MK_ABQ
Contributor
3 years agoThanks found it.
