14 years agoQSYS and JTAG Debugger
I have a design I've built in QSYS using a 16-bit bus. I'd like to include the JTAG to Avalon Master in my design so that I can do a quick system-level check using TCL commands before handing it off ...
14 years agoThe JTAG-to-Avalon-MM master has a 32-bit data bus. See Chapter 18
http://www.altera.com/literature/ug/ug_embedded_ip.pdf Under SOPC Builder you do not have any option to change the bus width. I assume that under Qsys its the same. The Qsys system builder should insert width adapters. If it does not, just create your own components with 32-bit widths, and generate two 16-bit transactions if all byte-enables are enabled. This is what I do to make 16-bit SRAM look like 32-bit SRAM. Cheers, Dave
