QSPI DDR Interface with Cyclone10LP: Maximum frequency
We are planning to implement a QSPI interface between Altera Cyclone10LP (10CL025YU256A7G) and a microcontroller iMXRT1180. The microcontroller is capable of a maximum frequency of 166 MHz (which would mean 332MHz DDR) on the QSPI interface. We want to know which would be the maximum frequency we are able to achieve on the FPGA for this interface.
We have this information extracted from the datasheet: "I/Os using general-purpose I/O standards such as 3.3-, 3.0-, 2.5-, 1.8-, or 1.5-LVTTL/LVCMOS are capable of a typical 200 MHz interfacing frequency with a 10 pF load." Does this mean the pins will not be able to accept data changing at a rate faster than 200 MHz or will it be possible to have something like a fHSCLK of 200 MHz (which would mean double device operation in Mbps) as we can see in Table 24 (example for RSDS Transmitter) on the datasheet?
Are there any special pins on the FPGA which we can use to achieve maximum potential on this interface? Or any strategies like using IDDR/ODDR modules that could help? Any suggestions are welcome.
Thank you!
