Purchasing IP license for Intel JESD204B IP core
Hi Terry Simpson,
Thank you for your feedback.
Did you manage to generate the Assembler report?
From the report you can see similar view as below to see which is license or unlicensed:
Assembler report example
Based on the JESD204B Intel® FPGA IP User guide under chapter 2.1 Release information, you can see the ordering code for this IP is "IP-JESD204B". You may share the assembler report and User Guide to double confirm with your distributor.
JESD204B Release information
You may refer to below link for more information:
JESD204B Intel® FPGA IP User Guide - 2.1. Release Information
Hope this answer your question.
Thank you.
ZulsyafiqH_Intel
While the various IP license names are not totally aligned, I now have enough confidence that the license sold by the distributor is the correct one.
- The assembler report shows that I need license “JESD204B”
- The User Guide section 2.1 shows “IP-JESD204B”
- The distributor sells “IP-JESD204B”
Thanks for your help. Please close this case.
Terry
