Purchasing IP license for Intel JESD204B IP core
Hi Terry Simpson,
Apologize for the delayed response.
Regarding to your question, I might not be able to direct if the license is the correct one or which license you require without looking at the project.
However I can suggest to you to apply an Intel 90-Day Evaluation License use with Quartus Pro/Standard (Free licensing trial).
Login to Intel® FPGA Self Service Licensing Center and request the Quartus evaluation free license here: https://licensing.intel.com/
1) Go to Sign up for Evaluation or Free licenses
2) Select Intel® FPGA EVALUATION-LIC
3) # of Seats is always 1
4) Check the T&C box
5) Add the required options
6) Click Get License button
Once you run your project compilation, Quartus will automatically create a assembler report, .asm.rpt file.
( The assembler report is located in <Project directory>/Output_files/<project_name>.asm.rpt.)
In this report will show which IP license that you do not have.
You may refer to below KDB as your reference:
FPGA Knowledge Base Article ID: 000080459 - IP licensing
Hope this answer you question.
May I know if are you using Intel development kit?"
Thank you.
ZulsyafiqH_Intel
- Terry63 years ago
Thanks for the response.
I went through the process you described above, generated the trial license and loaded it into Quartus, however, the JESD204B license is not included in the trial license.
Note that I can build a temporary design and use the generated programming file with JESD204B IP in Evaluation Mode. In this mode, the config file and IP is functional for 1 hour and requires the JTAG cable to be connected to the hardware.I am still not confident that the IP license sold by distributors is the correct one for my application, device, Quartus version, IP version, etc.
Thanks again,
Terry
