abraham1's avatar
abraham1
2 years ago
Provide details for the - FFV1_ITEMMASTER_20240221
​Below is the information needed as per request.
ITEM NUMBER: FFV1H-ICS-1080-00
MPN_DESCRIPTION: IC, FPGA, AGILEX 7-M, AGMG039R47A2E2V, MEDIUM SPEED, EXTENDED TEMP, BGA4700
MANUFACTURER PART NUMBER (MPN): AGMG039R47A2E2V
  1. ABOVE DESCRIPTION MATCHES WITH MPN ? (YES / NO) ?:
  2. GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT / INVALID ?:
  3. IS THIS MPN AVAILABLE IN TAPE & REEL PACKAGING OPTION ? (YES / NO) ?:
  4. IF YES, PROVIDE US CORRECT & ORDERABLE TAPE & REEL PART NUMBER ?:
  5. PROVIDE US CORRECT & ORDERABLE PART NUMBER FOR PURCHASE ORDER #PO's ?:
  6. LIFE CYCLE STATUS (ACTIVE / OBSOLETE / NRND) ?:
  7. PART MARKING ?:
  8. MOUNTING TYPE: SURFACE MOUNT TECHNOLOGY (SMT) ? (YES / NO) ?:
  9. MOISTURE SENSITIVITY LEVEL (MSL) ?:
  10. PACKAGING TYPE (TAPE & REEL, ROLL, TRAY, TUBE, AMMO, BULK etc.) ?:
  11. ROHS COMPLAINT ? (YES / NO) ?:
  • NazrulNaim_Intel's avatar
    NazrulNaim_Intel
    Nazrul Naim
    NazrulNaim_Intel
    Sorry for the delay. Below is the information needed as per request.
    ABOVE DESCRIPTION MATCHES WITH MPN ? (YES / NO) ?: YES
    GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT / INVALID ?: Correct & Orderable
    IS THIS MPN AVAILABLE IN TAPE & REEL PACKAGING OPTION ? (YES / NO) ?: NO
    IF YES, PROVIDE US CORRECT & ORDERABLE TAPE & REEL PART NUMBER ?: N/A
    PROVIDE US CORRECT & ORDERABLE PART NUMBER FOR PURCHASE ORDER #PO's ?: AGMG039R47A2E2V
    LIFE CYCLE STATUS (ACTIVE / OBSOLETE / NRND) ?: Active
    PART MARKING ?:
    MOUNTING TYPE: SURFACE MOUNT TECHNOLOGY (SMT) ? (YES / NO) ?: YES
    MOISTURE SENSITIVITY LEVEL (MSL) ?: 3
    PACKAGING TYPE (TAPE & REEL, ROLL, TRAY, TUBE, AMMO, BULK etc.) ?: TRAY
    ROHS COMPLAINT ? (YES / NO) ?: YES
    Hope that answers your question.
    Nazrul Naim
    NazrulNaim_Intel
    Good day
    Thank you for reaching out. I'm Nazrul Naim looking into your issue and allow me some time to look into your issue. I shall come back to you with findings.
    Thank you for your patience.
    Nazrul Naim
