Provide details for the - FFV1_ITEMMASTER_20240221
Below is the information needed as per request.
ITEM NUMBER: FFV1H-ICS-1080-00
MPN_DESCRIPTION: IC, FPGA, AGILEX 7-M, AGMG039R47A2E2V, MEDIUM SPEED, EXTENDED TEMP, BGA4700
MANUFACTURER PART NUMBER (MPN): AGMG039R47A2E2V
- ABOVE DESCRIPTION MATCHES WITH MPN ? (YES / NO) ?:
- GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT / INVALID ?:
- IS THIS MPN AVAILABLE IN TAPE & REEL PACKAGING OPTION ? (YES / NO) ?:
- IF YES, PROVIDE US CORRECT & ORDERABLE TAPE & REEL PART NUMBER ?:
- PROVIDE US CORRECT & ORDERABLE PART NUMBER FOR PURCHASE ORDER #PO's ?:
- LIFE CYCLE STATUS (ACTIVE / OBSOLETE / NRND) ?:
- PART MARKING ?:
- MOUNTING TYPE: SURFACE MOUNT TECHNOLOGY (SMT) ? (YES / NO) ?:
- MOISTURE SENSITIVITY LEVEL (MSL) ?:
- PACKAGING TYPE (TAPE & REEL, ROLL, TRAY, TUBE, AMMO, BULK etc.) ?:
- ROHS COMPLAINT ? (YES / NO) ?:
- NazrulNaim_Intel
Good day
Thank you for reaching out. I'm Nazrul Naim looking into your issue and allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
- NazrulNaim_Intel
Sorry for the delay. Below is the information needed as per request.
ABOVE DESCRIPTION MATCHES WITH MPN ? (YES / NO) ?: YES
GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT / INVALID ?: Correct & Orderable
IS THIS MPN AVAILABLE IN TAPE & REEL PACKAGING OPTION ? (YES / NO) ?: NO
IF YES, PROVIDE US CORRECT & ORDERABLE TAPE & REEL PART NUMBER ?: N/A
PROVIDE US CORRECT & ORDERABLE PART NUMBER FOR PURCHASE ORDER #PO's ?: AGMG039R47A2E2V
LIFE CYCLE STATUS (ACTIVE / OBSOLETE / NRND) ?: Active
PART MARKING ?:
MOUNTING TYPE: SURFACE MOUNT TECHNOLOGY (SMT) ? (YES / NO) ?: YES
MOISTURE SENSITIVITY LEVEL (MSL) ?: 3
PACKAGING TYPE (TAPE & REEL, ROLL, TRAY, TUBE, AMMO, BULK etc.) ?: TRAY
ROHS COMPLAINT ? (YES / NO) ?: YES
Hope that answers your question.
Nazrul Naim
- NazrulNaim_Intel
Nazrul Naim
