CLa_R's avatar
CLa_R
7 years ago
Protection diode for FPGA IO pins
Hi to all.
For my project I am using a Cyclone IV-E FPGA.
The lowest input voltage on its IO pins is -0.5V (as showed on Altera datasheet).
I have many input that can be lower that -0.5v (around -3v beacause its come from analog comparator) but for me their value condsidered as 0V.
Can I use a diode as protection of FPGA IO pins and to interpreted the negative voltage values as 0/GND?
  • CLa_R's avatar
    CLa_R
    Thanks for the reply.
    I still have some doubts concerning the input impedance, in my case, I use a 3.3V LVTTL level, but in table 6.2 I don't see any value of the input resistance.
    How should I interpret?
  • CLa_R's avatar
    CLa_R
    I'm also trying this scheme, which uses a N type MOSFET.
    Which is the best solution?
    Also, what is the input impedance of IO PINs of the FPGA?
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Yes, We can use external diode so that we can meet the devices absolute maximum DC input voltage and maximum allowed overshoot/ undershoot voltage requirements.
    Anand
    • CLa_R's avatar
      CLa_R
      Thank you.
      Even if it's not properly referring to FPGAs, could you tell me a suitable diode?
      In the meantime, I have come up with another solution, which uses a transistor and which should be both faster and safer than the diode. I enclose the scheme. What do you think?
        AnandRaj_S_Intel
        >>Sorry we can'l recommend any part number However you can refer development kit schematics for it.
        >>Yes, Design with MOSFE looks good, Even i have used it in my first project.
        Anand
