RHI
5 years agoProgramming via rbf file stopped working
A few years ago we developed a bootloader application for Cyclone V E that receives an application.rbf file via UART (in NIOS II) and then writes the data into the EPCQ32 flash device for. It then sw...
NurAiman_M_Intel
5 years agoHi,
How did you generate the .rbf file? And did you choose 4 bytes addressing?
Aiman
- RHI5 years ago
Hi
I used the original rbf file generated after compiling the project.
I also generated the rbf file through the GUI (Convert Programming Files). There are no option for 4 byte addressing.
Both of these options do not work.
