RHI
5 years agoOn point 3,4 and 5 of the post, the difference is due to generating the pof files either as 1-bit passive or 4-bit passive configuration. Also using the 4-bit passive configuration generating pof files has the exact same result as generating a rbf file except that the pof file has an extra header and footer and holds the entire memory content.
The question still stands, why does the original rbf file not work?
