RHI
5 years agoProgramming via rbf file stopped working
A few years ago we developed a bootloader application for Cyclone V E that receives an application.rbf file via UART (in NIOS II) and then writes the data into the EPCQ32 flash device for. It then sw...
RHI
5 years agoI wrote a small C program that takes a snippet from the bootloader-application.pof (Note the strange thing: it is the pof file) that was genereated via the GUI application selecting the sof files of both bootloader and application. The snippet is from the application start address + 152 bytes to the end of the file. I then saved this snippet as an rbf file and programmed it through the bootloader application. This actually boots the application and everything works.
Why does the original application.rbf not work, while the above does the trick?
