9 years agoProgramming tools on ARRIA 10 with windows XP
I'm generating my *.sof with the Quartus version 16.1 on Linux server. Nevertheless, my SW team need to work on windows XP on programming the FPGA on this old windows version. Any knows which program is compatible with XP? Thanks, BR, Julien4 Replies
--- Quote Start --- Then you will need to use a device older than arria 10. --- Quote End --- Alright, Thanks for the answer. - Altera_Forum
--- Quote Start --- Thanks for your answers, I noticed what you said by installing all the version of Quartus from 13.1 on XP. So, I was looking for a another programming tools compatible with XP. Unfortunately, it's impossible for us to change the OS. Thanks, BR, Julien --- Quote End --- Then you will need to use a device older than arria 10. - Altera_Forum
--- Quote Start --- From an old post: You ~really~ need to find some new s/w folks if they are still stuck at WinXP ... --- Quote End --- Thanks for your answers, I noticed what you said by installing all the version of Quartus from 13.1 on XP. So, I was looking for a another programming tools compatible with XP. Unfortunately, it's impossible for us to change the OS. Thanks, BR, Julien - Altera_Forum
From an old post:
--- Quote Start --- Quartus 13.1 is the last version that will run on Windows XP 32b and Windows 7 32b (and it will run on Windows 7 64b also). Quartus 14.0 and later require Windows 7 64b (not 32b) and later (Windows 8.1). Quartus 16.0 is the first version that will run on Windows 10 64b (also will run on Windows 7/8.1 64b). So if you have to run on WinXP 32b you will need to download the 13.1 version of Quartus. Or else upgrade to Windows 7 64b (or 8.1 64b). --- Quote End --- You ~really~ need to find some new s/w folks if they are still stuck at WinXP ...
