10 years agoProgramming the ArriaV -> where the data is kept?
Hi All, I just programmed the Fabric portion of ArriaV using Altera Blaster. Everything works perfect, but when I power down the board, all the programmed contents are violated. Why? Wher...
10 years agoThe sof file isn't enough to work with flash. Use the Quartus File->Convert Programming Files... command to create the proper type of file (probably .pof). You can then use the Quartus programmer to program the pof file into your flash.
