10 years agoProgramming the ArriaV -> where the data is kept?
Hi All, I just programmed the Fabric portion of ArriaV using Altera Blaster. Everything works perfect, but when I power down the board, all the programmed contents are violated. Why? Wher...
10 years agoHow you want FPGA to configure from the memory will determine configuration scheme that you want to use. I recommend you to also read the device handbook (Configuration chapter), so that you know what type of programming file you need to have and how to generate them.
