10 years agoProgramming the ArriaV -> where the data is kept?
Hi All, I just programmed the Fabric portion of ArriaV using Altera Blaster. Everything works perfect, but when I power down the board, all the programmed contents are violated. Why? Wher...
10 years agoSee chapter 18 - "quartus ii programmer" of the quartus ii handbook volume 3: verification (https://www.altera.com/en_us/pdfs/literature/hb/qts/qts_qii5v3.pdf).
Can I also suggest you tell us a little about the hardware you're using? We can probably give you a bit of a headstart... Cheers, Alex
