10 years agoProgramming the ArriaV -> where the data is kept?
Hi All, I just programmed the Fabric portion of ArriaV using Altera Blaster. Everything works perfect, but when I power down the board, all the programmed contents are violated. Why? Wher...
10 years agoThe FPGA's memory are volatile where your program will be erased after power off. You would need external memory devices to reprogram the FPGA every time you power up the FPGA.
