10 years agoProgramming the ArriaV -> where the data is kept?
Hi All, I just programmed the Fabric portion of ArriaV using Altera Blaster. Everything works perfect, but when I power down the board, all the programmed contents are violated. Why? Wher...
10 years agoMost dev boards have at least one non-volatile configuration flash. The way this is programmed varies depending on which of several configuration method(s) are used. Check the user manual of your board for details. The Quartus programmer manual has information on preparing the file needed when programming the configuration flash.
