10 years agoProgramming the ArriaV -> where the data is kept?
Hi All, I just programmed the Fabric portion of ArriaV using Altera Blaster. Everything works perfect, but when I power down the board, all the programmed contents are violated. Why? Wher...
10 years agoI assume you're configuring the FPGA directly using a '.sof' file...
FPGAs are volatile devices - they have no FLASH. They store their configuration image in SRAM while operating. SRAM doesn't store anything when you power them off. --- Quote Start --- Should I do something special in order to keep the programming data --- Quote End --- Read through Chapter 8 - 'configuration, design security, and remote system upgrades in arria v devices' - of the arria v device handbook (https://www.altera.com/en_us/pdfs/literature/hb/arria-v/av_5v2.pdf). Cheers, Alex
