Programming the Arria 10 GX FPGA Development Kit
Did you auto select the device in the Programmer or manually select it? Try manually selecting the device.
And show a screenshot of what the Programmer is showing you.
I've selected both devices (different compilations) and selected the devices manually in the Programmer. Programming fails with either compiled .sof file.
Here's the programmer and error message with 10AX115S2F45I2SG selected:
Error (209015): Can't configure device. Expected JTAG ID code 0x02E660DD for device 1, but found JTAG ID code 0x020A30DD. Make sure the location of the target device on the circuit board matches the device's location in the device chain in the Chain Description File (.cdf).
Here's the programmer and error message with 10AX115S2F45I1SG selected:
Any ideas? Thanks.
