Programming sof using different firmware
The Quartus programmer requires the firmware to program the sof. Does Quartus utilize firmware content during the compilation?
- NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- NurAiman_M_Intel
@FvM response is correct.
Additionally, we are unable to provide further information on this as this is confidential. Apologize for the inconveniences.
Aiman
- NurAiman_M_Intel
What is the function of these zip files in the firmware folder ? Do we have any use case where the zip is being used?
- May I know the reason on why you need to know this information?
Aiman
- Chris039
Hi Aiman,
I just want to understand the usage of the firmware in this folder, when and how it is being used.
- Chris039
- FvM
as far as I'm aware of, "firmware" folder isn't used by Quartus programmer and neither in compilation. It's a toolkit for debugging purposes. In previous Quartus versions, it's located at quartus/common/devinfo/programmer/firmware. - Chris039
The firmware is the device firmware used during the sof programming. It is located in C:\intelFPGA_pro\23.1\devices\programmer\firmware.
Does Quartus use the information in the firmware during the compilation?
- FvM
Not quite clear which firmware you mean. Generally Quartus programmer doesn't use firmware, except for USB Blaster II. Its driver (not Quartus programmer) loads a firmware for USB Blaster microcontroller.
