acremann
1 year agoProgramming of the CRAM of a Max10 using svf file
Dear all, We try to program the configuration RAM (CRAM) of a Max10 from an svf file. This works well, but in addition, something non-volatile is altered on the Max10 as well: a previous configurati...
acremann
1 year agoHi
OK, I looked closer into the error message: After programming the CRAM using the svf file (attached below in a zip file) the CFM gets actually erased! Below the screen shot of the Programmer blank check; the CFM is empty.
So it looks like the svf file used to program the CRAM causes an erase of the CFM as a side effect.
Best,
Yves
