acremann
1 year agoProgramming of the CRAM of a Max10 using svf file
Dear all, We try to program the configuration RAM (CRAM) of a Max10 from an svf file. This works well, but in addition, something non-volatile is altered on the Max10 as well: a previous configurati...
Farabi_Altera
1 year agoHello,
Can you slow down the TCK and see if it can pass?
TCK range = 6Mhz - 24Mhz
regards,
Farabi
acremann
1 year agoDear Farabi
I tried that, there is no change if I set a different clock frequency (in this case 6 MHz).
I guess the code in the svf file somehow overwrites some non-volatile memory cells on the Max10.
Best,
Yves
