9 years agoProgramming Issue with Active Serial Programming
We are trying to program a EP1C12Q240C8N device using Quartus II 6.0 Web on a Windows 7 PC with the Byte Blaster II programmer. Getting a cannot recognize silicon device ID error. The programming ope...
9 years agoThanks to both of you for your help. I am having trouble determining if the USB Blaster will work with the version of Quartus that supports this older device. From what I can tell, this is first generation Cyclone, and 11.1 is the latest version that can be used. The USB Blaster II requires version 14. The USB Blaster does not specify the version, so perhaps it would work with 6, or 11.1? The download cables aren't cheap, even though it isn't my money, I would rather not spend the company's money on something that may not work.
