Programming EPCQ from External processor
The remote update IP is only use to remotely reconfigure the FPGA with the new bitstream. It cannot be use to update the EPCQ device.
You use any interface connected to the FPGA where the interface IP need to communicate with the Generic Serial Flash Interface IP (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-gen-sfi.pdf) in order to update the EPCQ flash.
Thanks for the reply. With respect to using "Generic Serial Flash Interface IP", I have couple of questions.
1) Do you have any source code / reference design to interface the External processor to JTAG UART module of FPGA?
2) We are not planning to use Quartus programmer or any Intel tools from Host PC to update the EPCQ device. Is it possible to update without Quartus programmer or Nios console to interface between External processor & FPGA .
With Regards,
HPB
