11 years agoProgramming Cyclone IV FPGA using USB Blaster Rev A
Hi, I am testing a custom Cyclone IV board. I am using USB BLASTER Rev.A to program the FPGA via JTAG as well as AS modes. I am able to configure the EPCS64 configuration memory when USB Blaste...
11 years agoI have a rev B cable working quite happily with Cyclone IV and I'm (pretty) sure I used to have a rev A cable doing the same. The only difference between rev A & rev B is they changed from ribbon cable (on A) to a flexible PCB cable.
I also have a USB-Blaster rev B whose flexible cable broke. I replaced it with standard ribbon cable but ended up having to reduce it's length to get it working. So, I can well imagine you having issues with your rev A cable. I suggest you try reducing the length if the ribbon cable. Mine ended up pretty short... https://www.alteraforum.com/forum/attachment.php?attachmentid=11055 ...much shorter than necessary. Cheers, Alex
