11 years agoProgramming cyclone III & IV using a custom USB Blaster
Hi all, I'm trying to make a USB blaster circuit. I'm prototyping with a cyclone III connected to an FTDI IC. This combination is effectively the same as you might find in devkits that have e...
11 years agoYou can't use your FTDI device 'as is'. The Quartus programmer, or more specifically the driver, is looking for a particular Vendor & Product ID (VID & PID), stored in the FTDI device, before it'll recognise it as a USB-Blaster. Only then will the driver decide it knows how to control it. So, unless you reprogram you FTDI device the driver is never going to recognise it as a USB-Blaster or interact with it.
--- Quote Start --- Transferring raw data from FTDI to JTAG pins is a managable task with a CPLD or FPGA --- Quote End --- Indeed, it is a manageable task - the USB-Blaster does this with a CPLD. However, this is where you'll struggle - I referred to Altera's propitiatory (secret) CPLD design. --- Quote Start --- I think that if I use .rbf files, I could manage to download them --- Quote End --- Again, yes - in theory. However, unless you know how the FTDI device presents the data to the CPLD or FPGA - which is dependent on what the driver sends to it, including whatever protocol is used - then you won't solve this. Yes, you get embedded USB-Blasters on dev kits. However, they are manufactured by Altera or their partners, who are trusted with the CPLD design required. Cheers, Alex
