11 years agoProgramming cyclone III & IV using a custom USB Blaster
Hi all, I'm trying to make a USB blaster circuit. I'm prototyping with a cyclone III connected to an FTDI IC. This combination is effectively the same as you might find in devkits that have e...
11 years agoThanks Alex,
But I want to use the FTDI - **AS IS**, and not clone Altera's Blaster's FTDI's innards, because my FTDI is already a part of another working system. So, is there a way you can suggest to make it work under these conditions? As per your inquiry- I think that if I use .rbf files, I could manage to download them onto a target device (i.e. program it). Transferring raw data from FTDI to JTAG pins is a managable task with a CPLD or FPGA, in my opinion. Thanks again, David
