Fpedga
4 years agoProgramming Arria 10 after setting non-volatile key and tamper protection
I set the non-volatile key and tamper protection in Arria 10 (I checked using the KEY_VERIFY via JTAG and everything seems good).
The thing is I can't load my JIC using Quartus Programmer...
FakhrulA_altera
4 years agoHi Fpedga,
May I know what is the version you're using now?
There is a few KDBs related to your issue.
You may take a look and see if this workaround is applicable to your issue:
Error (209014): CONF_DONE pin failed to go high in device 1
Error (209014): CONF_DONE pin failed to go high in device 1.
Error (209014): CONF_DONE failed to go high in device <number>
Fakhrul
