akifh
2 years agoProgramming Altera Max EPM3256AQC208-10N PQFP-208
Hello, I have an Altera Max EPM3256AQC208-10N PQFP-208, the chip is not connected to the card but is single. How can I read the data in this chip and programming data into it? Which devices should I ...
_AK6DN_
2 years agoWell, you will likely either have to solder it to a small test board with a breakout pattern, or use something like this:
https://www.aliexpress.com/i/2251832626235520.html?gatewayAdapt=4itemAdapt
where you can then easily wire up power, ground and the JTAG signals you require.
QuartusII 13.0sp1 is still available for programming this device, but I don't believe it is capable of reading back programmed device images.
You would likely need to use a third party device programmer to do image readback.
