agieson_cl
1 year agoProgrammer not working with MX25U25645GXDI54 NOR Flash [Cyclone 10 GX]
Hi! I'm working with a Cyclone 10 GX FPGA [220KLE] and I am not able to program my MX25U25645GXDI54 NOR Flash. The hardware design has been validated as I am able to program a MT25QU256ABA8E12 NOR F...
agieson_cl
1 year agoconsole output from the programmer:
Info(16677): Loading synthesized database.
Info(16678): Successfully loaded synthesized database: elapsed time is 00:00:00.
Info: Detected assignments have changed since last compile for: Analysis & Synthesis.
Info(209060): Started Programmer operation at Mon Sep 29 09:19:13 2025
Info(209016): Configuring device index 1
Info(209017): Device 1 contains JTAG ID code 0x02E120DD
Info(209007): Configuration succeeded -- 1 device(s) configured
Info(19845): Start Serial Flash Loader programming
Error(209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly.
Info(19845): End Serial Flash Loader programming
Error(209012): Operation failed
Info(209061): Ended Programmer operation at Mon Sep 29 09:19:19 2025
