17 years agoProgram MAX3000 without JTAG?
Hi, I'm going to use the MAX3000A (EPM3032A) in a project and I need 34 i/o ports so I will have to disable the JTAG port and use the four JTAG pins as I/O. I've found the setting in Quartus t...
16 years agoI assume, that Altera provides the HV programming specification for programmer manufacturers and that it's actually supported by industry standard programmers and test equipment with programming features. You may want to ask either the respective vendors or Altera about it.
