17 years agoProgram MAX3000 without JTAG?
Hi, I'm going to use the MAX3000A (EPM3032A) in a project and I need 34 i/o ports so I will have to disable the JTAG port and use the four JTAG pins as I/O. I've found the setting in Quartus t...
17 years agoMAX3000A has an option for high-voltage programming through Altera Programming Unit (APU) and some third party programmers. I didn't see a documentation for high voltage programming in datasheet, there's only a remark that OE1 is used as high–voltage pin during programming.
