9 years agoProgram EPM7064 to match EPS464
I have a pof file used on the EPS464 device. Due these devices being discontinued I am trying to use the EPM7064 as a substitute. The EPM7064 is mentioned by ALtera as pin compatible to t...
9 years ago --- Quote Start --- Hi Jeff, Just would like to understand if the POF file you used is EPS464? If yes, I believe you would need to compile the design to be compatible with EPM7064 before convert it to POF. --- Quote End --- Yes, the POF file used was originally for the EPS464. So, if I can locate the original design files I can compile to work on the EPM7064. So far that's my issue, locating the original design files. My guess is there's no way to uncompile the POF. THanks for relpying. Jeff
