pdi_eng
5 years agoProcess of Programming Kills FPGA
We have had some instances where programming an FPGA appears to kill the FPGA.
For instance, we had two boards that has a Cyclone III and wouldn't program because Quartus said it couldn't access th...
YuanLi_S_Intel
5 years agoYes i understand. It looks like the issue is that the pin is having issue after programming via JTAG and it is happening on some board only.
Have you check the signal integrity on the board? Is there any issue affecting the pin on the board? Have you tried with another piece of USB Blaster on the failure board?
