Procedure to add uClk_usr in Streaming DMA AFU
I want to run my AFU in uClk_usr domain in the Streaming DMA AFU sample example. Please can you provide the steps that need to be followed in order to achieve this.
Thank you
- Navaneeth
We tried using uClk_usr instead of pClk in line 117 of "ccip_std_afu.sv" file. We got the following error when we ran the software in simulation mode:Thank you
- JohnT_Altera
Sorry, I was looking at the wrong directory. After looking at the correct directory then I am able to find the file.
You can modify the file in ccip_std_afu.sv so that the AFU IP is using UserClk and not Pclk.
- Navaneeth
Upon checking, the "avst_decimator.sv" file does not have user clock as input in this version as well.
Thank you
- JohnT_Altera
- JohnT_Altera
Could you try to download the official version and check if you can work with the latest AFU design?
- Navaneeth
I am not sure about the DCP Version.We are accessing the streaming dma afu folder by:
1. SSHing into devcloud
2. "devcloud_login" into "Stratix 10 PAC Compilation and Programming - RTL AFU, OpenCL" node
3. Performing "tools_setup" of "Stratix 10 PAC Compilation and Programming - RTL AFU, OpenCL"
4. cd "$OPAE_PLATFORM_ROOT/hw/samples/streaming_dma_afu"
The path to avst_decimator.sv is
"$OPAE_PLATFORM_ROOT/hw/samples/streaming_dma_afu/hw/rtl/QSYS_IPs/avst_decimator/avst_decimator.sv"Expanded path is "/glob/development-tools/versions/fpgasupportstack/d5005/2.0.1/inteldevstack/d5005_ias_2_0_1_b237/hw/samples/streaming_dma_afu/hw/rtl/QSYS_IPs/avst_decimator/avst_decimator.sv"
Thank you
- JohnT_Altera
May I know if you are using DCP 2.0.1? For this version, I do not see this IP
- Navaneeth
Path to avst_decimator.sv is:<path to streaming_dma_afu folder>/hw/rtl/QSYS_IPs/avst_decimator/avst_decimator.sv
OR
Thank you
- JohnT_Altera
Where can I get the avst_decimator.sv file? I am not able to see the file in the AFU design.
- Navaneeth
Yes, "afu.sv" is using the afu_clk.
But, it would be great if the uClk_usr is made available in avst_decimator.sv file.Thank you
