Navaneeth
4 years agoProcedure to add uClk_usr in Streaming DMA AFU
I want to run my AFU in uClk_usr domain in the Streaming DMA AFU sample example. Please can you provide the steps that need to be followed in order to achieve this.
Thank you
JohnT_Altera
4 years agoHi,
You will need to try to recompile your design in different seeds to see if it is able to close the timing. May I know if the timing issue will impact your testing?
Navaneeth
4 years agoHi,
To reiterate the issue that we’re facing, it is that the timing constraints are not being met when we are synthesising our code using quartus for the purpose of getting the GBS file as output. The error files are attached in one of the previous messages.
We want to know how we can send a lower frequency of clock (user clock having 300 MHz) in the right manner to the avst decimator file so that we don’t get the timing constraints not met error.
We’re referring to the streaming dma afu bbb provided by Intel.
Thank you
