Navaneeth
4 years agoProcedure to add uClk_usr in Streaming DMA AFU
I want to run my AFU in uClk_usr domain in the Streaming DMA AFU sample example. Please can you provide the steps that need to be followed in order to achieve this.
Thank you
JohnT_Altera
4 years agoHi,
Usually the AFU does not need to have a special SDC for it as it is covered in the default SDC.
- raks4 years ago
I tried using uClk_usr with the help of clock crossing module. I instantiated the clock crossing module in the ccip_std_afu.sv file and in spite of that, I got the "timing constraints not met" error. What is the reason for getting that error and how to rectify it?
Thank you
