Navaneeth
4 years agoProcedure to add uClk_usr in Streaming DMA AFU
I want to run my AFU in uClk_usr domain in the Streaming DMA AFU sample example. Please can you provide the steps that need to be followed in order to achieve this.
Thank you
JohnT_Altera
4 years agoHi,
After further checking, the rtl should not be change. You will need to modify the json file so that it is using uclk_usr. You may refer to "hello_mem_afu" example design json file.
