16 years agoProblems with Synthesis ?
Hola All, I've made some code that describes a counter that first adds one to a count "c", compares its value with an input "N", and if they are the same then a Hold_All bit goes high. I think ...
16 years agoI'm not sure it would change anything for the synthesizer, but could you try to move the line
Num_Val := To_Integer(N);inside the clock event part? I'm don't know how the synthesizer would handle your line outside of the if. It is better to stick as much as possible to the recommended structures.
