16 years agoproblems with programming neek
I've recently bought a neek kit. I tried all found niosII examples design, for example this standard one http://www.altera.com/support/examples/nios2/exm-std_nios2_hardware.html Generation and compilation is successful, but when it comes to programming I get the message: --- Quote Start --- Info: SRAM Object File xxxxx.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00A --- Quote End --- where "xxxxx.sof" is sof of any design What should I do is it normal when programming with web license? I ordered new license and everything is the same:mad: What should i do?1 Reply
It is normal. The license you are missing is for the IPs that you put in the FPGA, probably the NIOS itself. You can still configure your board and use it though, just keep the USB cable connected and don't close the alert window opened by the programmer.
